| | | Forums66 Topics128,180 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Removed front fenders from donor truck today,'55 1st 3/4 ton . noticed 1 hole in top of both fenders 3/8" about 7" from front of fender, they both was bondo over . Was these made by PO or factory ???? Thanks
" STUCK IN THE '50'S "
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Sounds like aftermarket lights to me. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Agreed - directional/marker lamps.
Not factory installed - installed by dealer/owner. There were GM accessory front-fender-mounted lamps and many types of after market front-fender-mounted lamps.
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks I'll weld the holes up ....
| | | | | Joined: Oct 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 55 | I filled mine in. Had no intention of keeping those farm truck type of lights on the fenders.
I did however run across one of my front fenders with two holes on the side, right over the front wheel opening. One fender has them, the other doesn't. I know they're from different trucks, but I have never seen these holes on the front fenders before. Almost as if someone meant to rivet a bracket there or something.
Anyone else seen these before? Maybe know what they were used for?
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Plumber truck. Rack mount to hold pipe in long lengths would have been on the passenger side. Dads truck had them and he hated them moved to under the bumper and he was happy. My job was to lift the pipe as he pushed it under the truck.
Steve H
| | | | | Joined: Oct 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 55 | Steve H. Thank you for that information. You're right, these ARE on the passenger side front fender.
Settles that question...now off to weld them shut so I'm that much closer to being ready for a paint booth! | | |
