8 members (Wayne67vert, TUTS 59, Hotrod Lincoln, Otto Skorzeny, klhansen, Shaffer's1950, Dragracefan, fonz8261),
172
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | I just finished getting the momtor in my truck (LS1/4L80e). Now I am finishing up small parts of the wiring. I am trying to get the tail lights/tun signals done. Can anyone tell me what the functions are of the 5 terminals sitting the the connector on the lower portion of the steering colum (looks like this from top view) http://73-ls1.com/63truck/Connector.bmp There is no male connector going to it so I have no rear lights. I think I'll have to build a small harness. Thanks in advance.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming 1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic 1967 Convert Continental: Stock Cruiser
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Super73, I have no definitive answer for the question, but maybe this site will help. Good luck. http://www.6066gmcguy.org/turnlights1.htm Stuart | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | HELLO Stuart, your tail lights will come off of your headlight switch, the five wires should be six wires 1 for lt front,1 for rt front 1 for lt rear 1 for rt rear,1 for stop(from brake switch)1 for power(unless power is not in that plug) is there any other wires going up the colum? the dash indacators will come of the front turn signals,the stop lights will come through the rear turn signals, | | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | Giant, I did not pull the connector off the colum and was feeling it out with a finger so there very well may be 6 terminals there. As far as anything else on the column, I didn't see anything. I'll look at the headlight switch and see if there is a harness coming off of it. Perhaps the other end is hanging there and I just don't see it  Sure would make life a little easier. Any idea which terminals go to what? If I knew the power one, I'm sure I could figure out the rest fairly quickly. Thanks in advance.
