7 members (Wayne67vert, 32Fordpuchoptop, Peggy M, mo2cyl, Stovebolt48, tclederman, asilverblazer), 177 guests, and 0 robots.
Topics128,083
Posts1,055,967
Members48,430
#101814 07/27/2007 7:28 PM
Junior Member
Junior Member
66 Chevy C10.
Headlight switch in off position = Brake lights and turn signals work great.
Headlights switch on position = Headlights work. Tail lights on but turn signals or brake lights dont work. Tali lights very bright as if brake being applied but not.
James T
www.fixmyprinter.com
But honey...its for us!
#101815 07/27/2007 7:34 PM
bad ground at the taillights
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#101816 07/27/2007 7:41 PM
I concur (I always wanted to say that) with 64fleetside. Bad ground. Check it at the place most people check last. The tail light housing.
Take the tail light housings out of the fenders completely. Get some sandpaper and clean all the area where the taillight assembly screws to the fender. Find some star washers to use under the screws. A little dialectric grease at that point of contact won't hurt.
#101817 07/27/2007 8:25 PM
James,
I'm going to disagree with the folks above. It seems if it were a taillight ground issue, that it would only effect the light with the problem...not both. I think it is something else, but I don't have a clue what that would be.
At first I thought 'mashed wires', where the brake light wire and taillight wire were bare and touching each other. If this were the case, when you applied the brakes, the brake AND tail lamps would illuminate! I'll wait for the smart guys to show up on this one! smile
Stuart
#101818 07/27/2007 8:48 PM
Hey Stuart I'm with you, but I sure hope I'm not the smart guy. I'd like to leave some room for error. grin
Headlights=on, tail lights but bright, both?
Headlights=off, tail lights and turn signals work, are they dim?
There are three wires to the rear lights, one is tail lights (black) which goes to both, the second and third are turn signal/brake (purple=left, violet=right) one to respective side. If the wiring is correct at the rear lights, and the bulbs are installed correctly, then the problem is either light switch or turn signal wiring. Check the light switch on the right side(?) from the panel they should be dark green, 2 orange to next terminal and then black (this maybe prob wht/blk switched) next see that all the colors on the turn signal harness match. I'm going by a 63 factory manual so there could be some errors. :rolleyes:
Larry
I don't own a vehicle that isn't old enough to drink.
#101819 07/27/2007 8:49 PM
Its a ground problem.
The turn and brake lights are grounding through the tail light circuit. You can test this by removing the lens and carefully grounding the lamp base and then checking to see what the lights do.
#101820 07/27/2007 9:01 PM
Steve,
Wouldn't this lack of ground have to be in BOTH taillight assemblies to affect both sides simultaneously?
Stuart
#101821 07/27/2007 9:50 PM
Quote
Originally posted by atomarc:
Steve,
Stuart
it generally is both, either thru corrosion in the lamps themselves or no ground strap(bed is bolted thru the wood)from frame to bed.
#101822 07/27/2007 10:06 PM
Brian,
If no ground strap to bed, how the heck do the brake lights function...so this problem is all of a sudden a lack of ground to both taillights only, not the brake lights. I get cornfused trying to draw little cartoons that show how the power is feeding back through odd filaments making them light up when they shouldn't. No cartoon I draw on this post makes both illuminate because of a faulty ground!
Stuart
#101823 07/27/2007 10:50 PM
The first question I would ask is, what, if anything, did you change between its working correctly and now? Or is this an initial setup from an unknown starting point?
#101824 07/28/2007 12:17 AM
The brake lights ground thru the tailight circuit & vice-versa, an 1157 bulb has 2 fliaments but only one ground(the bulb base)don't ask me how I'm no engineer I just know it does.
#101825 07/28/2007 12:44 AM
One possibility is that the brake light and the taillight wires are reversed in both taillight assemblies. The brake and turn lights would appear to work correctly (though they should be less bright than you would expect) and when the headlights are on, the brighter filament would make it difficult to see the brake or turn lights come on.
#101826 07/28/2007 2:12 AM
James,
You had a post on 7/17/07 in this forum dealing with a problem which is almost certainly related to this one. Is there more to this story than meets the eye. smile
Stuart
#101827 07/28/2007 3:47 AM
Junior Member
Junior Member
Looks like all of you weree riht in ways. I cleand up the ground and the brake lights went off and operated normaly with headlights on. I alos seems o have had one set up the lights wires reversed. Unsure how it worked at all but...bottom line all works well now. Thanks to all.
James T
#101828 07/28/2007 4:02 AM
WOW, multiple gremlins! Time for some Wild Turkey on the roxxxx......glad you triumphed.
Stuart
#101829 07/28/2007 4:40 AM
1 Offline
oops! too late :rolleyes:
