| | | Forums66 Topics128,089 Posts1,055,991 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | 66 Chevy C10.
Headlight switch in off position = Brake lights and turn signals work great.
Headlights switch on position = Headlights work. Tail lights on but turn signals or brake lights dont work. Tali lights very bright as if brake being applied but not. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | bad ground at the taillights | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I concur (I always wanted to say that) with 64fleetside. Bad ground. Check it at the place most people check last. The tail light housing.
Take the tail light housings out of the fenders completely. Get some sandpaper and clean all the area where the taillight assembly screws to the fender. Find some star washers to use under the screws. A little dialectric grease at that point of contact won't hurt. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James, I'm going to disagree with the folks above. It seems if it were a taillight ground issue, that it would only effect the light with the problem...not both. I think it is something else, but I don't have a clue what that would be. At first I thought 'mashed wires', where the brake light wire and taillight wire were bare and touching each other. If this were the case, when you applied the brakes, the brake AND tail lamps would illuminate! I'll wait for the smart guys to show up on this one! Stuart | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Hey Stuart I'm with you, but I sure hope I'm not the smart guy. I'd like to leave some room for error. Headlights=on, tail lights but bright, both? Headlights=off, tail lights and turn signals work, are they dim? There are three wires to the rear lights, one is tail lights (black) which goes to both, the second and third are turn signal/brake (purple=left, violet=right) one to respective side. If the wiring is correct at the rear lights, and the bulbs are installed correctly, then the problem is either light switch or turn signal wiring. Check the light switch on the right side(?) from the panel they should be dark green, 2 orange to next terminal and then black (this maybe prob wht/blk switched) next see that all the colors on the turn signal harness match. I'm going by a 63 factory manual so there could be some errors. :rolleyes: Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its a ground problem.
The turn and brake lights are grounding through the tail light circuit. You can test this by removing the lens and carefully grounding the lamp base and then checking to see what the lights do.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
Wouldn't this lack of ground have to be in BOTH taillight assemblies to affect both sides simultaneously?
Stuart | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by atomarc: Steve,
Stuart it generally is both, either thru corrosion in the lamps themselves or no ground strap(bed is bolted thru the wood)from frame to bed. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian,
If no ground strap to bed, how the heck do the brake lights function...so this problem is all of a sudden a lack of ground to both taillights only, not the brake lights. I get cornfused trying to draw little cartoons that show how the power is feeding back through odd filaments making them light up when they shouldn't. No cartoon I draw on this post makes both illuminate because of a faulty ground!
Stuart | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The first question I would ask is, what, if anything, did you change between its working correctly and now? Or is this an initial setup from an unknown starting point? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The brake lights ground thru the tailight circuit & vice-versa, an 1157 bulb has 2 fliaments but only one ground(the bulb base)don't ask me how I'm no engineer I just know it does. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | One possibility is that the brake light and the taillight wires are reversed in both taillight assemblies. The brake and turn lights would appear to work correctly (though they should be less bright than you would expect) and when the headlights are on, the brighter filament would make it difficult to see the brake or turn lights come on. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James, You had a post on 7/17/07 in this forum dealing with a problem which is almost certainly related to this one. Is there more to this story than meets the eye. Stuart | | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | Looks like all of you weree riht in ways. I cleand up the ground and the brake lights went off and operated normaly with headlights on. I alos seems o have had one set up the lights wires reversed. Unsure how it worked at all but...bottom line all works well now. Thanks to all. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | WOW, multiple gremlins! Time for some Wild Turkey on the roxxxx......glad you triumphed.
Stuart | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | oops! too late :rolleyes: | | |
