0 members (),
90
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | hello,
last summer i purchased a 1954 chevy 4400 stake 1.5 ton, or at least i was told. i have tried to research this truck but come up slim, but looks like the truck may be a 2 ton since it says gross weight is 16,000 lbs. the truck is purely canadian. so i was hoping someone could help me decipher the serial numbers and engine code.
heres the door placard numbers (having issues with my photobucket account)
model: 1543 serial: 4154300358 engine: T755478 (matches stamping on engine block) body serial: 34 Paint 438
Any help would be greatly appreciated if someone can completely decipher these numbers.
Thank you
1954 Chevy 2 ton stake Full pressure 235 12 volt 4 speed manual
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Elup, your truck is a Canadian 1954 1543 model, it has a 161" wheelbase, it is powered by a full pressure 235, and it left the factory as a chassis with cab. The comparable American model would be 4403 I believe, hope that helps. | | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | Hy Elup, your truck is a Canadian 1954 1543 model, it has a 161" wheelbase, it is powered by a full pressure 235, and it left the factory as a chassis with cab. The comparable American model would be 4403 I believe, hope that helps. Oh so it is a 1.5 ton truck if it is a 4403? I just found it odd the weight rating was 16,000lbs. Thank you
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Elup, if your front axle hub cap is an eight sided screw in type then it is a 1 1/2 ton, if the hub cap is bolted to the hub then it is a 2 ton (or someone has changed the axle). There are no comparable American models for some Canadian trucks, our 16 series (2 1/2 ton) and 17 series (3 ton) have no comparable American models as American Chevrolet trucks stop at 2 tons. Canadian 2 1/2 and 3 ton trucks are named Maple Leaf trucks, hope that helps. | | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | Hy Elup, if your front axle hub cap is an eight sided screw in type then it is a 1 1/2 ton, if the hub cap is bolted to the hub then it is a 2 ton (or someone has changed the axle). There are no comparable American models for some Canadian trucks, our 16 series (2 1/2 ton) and 17 series (3 ton) have no comparable American models as American Chevrolet trucks stop at 2 tons. Canadian 2 1/2 and 3 ton trucks are named Maple Leaf trucks, hope that helps. Well in the front the center cap has 4 bolts holding it down. In the rear the center cap has 5 bolts holding it. Thanks again for your knowledge
| | | | | Joined: Aug 2001 Posts: 3,598 Moderator | | Moderator Joined: Aug 2001 Posts: 3,598 | Good looking truck and welcome to the Stovebolt Page. There are no stupid questions here, so ask away.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | Anyone else opinion on this truck? 4400 (1.5 ton) or 6400 (2 ton)
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | If it has a 16,000 weight, I think that would make it a 2 ton or 6400 in the USA.
Bruce | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Elup, the chart I looked up the comparable American model in was in a 55B or 2nd series through 57 parts book, perhaps there is an error in the book or the earlier models didn't crossover the same way. At any rate a Canadian 1500 series is a two ton truck,hope that clarifies. | | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | Oh okay! Well thank you very much. And that also clarifies why the hood has a 1500 badge on it. I wondered if someone changed it along the way since I always thought 1500 meant 1/2 ton truck
