3 members (tclederman, TUTS 59, 1 invisible),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | How is your winter going?We've been mostly healthy. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy BC52, well we had a foot of snow yesterday, but healthwise we're doing okay. | | | | | Joined: Aug 2006 Posts: 18 New Guy | | New Guy Joined: Aug 2006 Posts: 18 | Hi BC52 Ditto what 3B said. Roge | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Winter has been very white out here. Dang big fir keeps dropping limbs, mostly next to my shop, but one made a landing. It put a big dent in my shiny new roof. Picked up my tractor from the states and working on the sheet metal. Fabricated a new lower section for the front shell and new mounting sections where it bolts to the frame, and bumped out some dents. Stripping off all the sheet metal to bare metal and getting ready to prime, but need some warm weather to heat up my "spray booth". Since I am not really an automotive painter I have been looking on line for the proper metal prep, primers, sealers etc.. and getting confused and a headache. Seems like painting isn't an exact science. So many conflicting ideas. I like this guys step by step procedure: http://rodnh.byethost12.com/acb/painting/painting2.htmOnce I get the tin done, then I am going to use the tractor to haul the big bolt into the shop to start on it. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | All is well here. Trying to get my 16" rims to paint and mount my wide white walls in time for 3B's picnic.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I'm gong to try and get mine ready for 3Bs.... just not sure what year. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Okay, I've been working. When is 3B's? Winter has been okay, really. Evelyn wrote her Yaris off in the worst of the storms, but she's fine, she learned something and I didn't like that car enough to see the event as a problem. Now she has a perfect '04 Mercedes C230. All good, and there's more: after a protracted absence, Epic is home. I posted this in the Greasy Spoon: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1017451#Post1017451
1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Good to see you back here,Mark.I've just read you post on the Epic#2.
| | | | | Joined: Oct 2012 Posts: 33 New Guy | | New Guy Joined: Oct 2012 Posts: 33 | I finally see the end of the tunnel on my project of my 41’ AK. If luck is on my side I will finally attend some meets or swaps this year ! Greetings all ! | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I look forward to meeting you,Michael | | |
