3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#1011325 03/03/2014 5:37 PM
How is your winter going?We've been mostly healthy.
3B Offline
Hy BC52, well we had a foot of snow yesterday, but healthwise we're doing okay.
Hi BC52
Ditto what 3B said.
Roge
Big Bolt Forum Co-moderator
Winter has been very white out here. Dang big fir keeps dropping limbs, mostly next to my shop, but one made a landing. It put a big dent in my shiny new roof. Picked up my tractor from the states and working on the sheet metal. Fabricated a new lower section for the front shell and new mounting sections where it bolts to the frame, and bumped out some dents. Stripping off all the sheet metal to bare metal and getting ready to prime, but need some warm weather to heat up my "spray booth". Since I am not really an automotive painter I have been looking on line for the proper metal prep, primers, sealers etc.. and getting confused and a headache. Seems like painting isn't an exact science. So many conflicting ideas. I like this guys step by step procedure: http://rodnh.byethost12.com/acb/painting/painting2.htm
Once I get the tin done, then I am going to use the tractor to haul the big bolt into the shop to start on it.
1948 Chevy 2-Ton
All is well here. Trying to get my 16" rims to paint and mount my wide white walls in time for 3B's picnic.
I'm gong to try and get mine ready for 3Bs.... just not sure what year.
1948 Chevy 2-Ton
Okay, I've been working. When is 3B's?
Winter has been okay, really. Evelyn wrote her Yaris off in the worst of the storms, but she's fine, she learned something and I didn't like that car enough to see the event as a problem. Now she has a perfect '04 Mercedes C230.
All good, and there's more: after a protracted absence, Epic is home. I posted this in the Greasy Spoon:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1017451#Post1017451
1951 3800
-hotshoe
Good to see you back here,Mark.I've just read you post on the Epic#2.
I finally see the end of the tunnel on my project of my 41’ AK. If luck is on my side I will finally attend some meets or swaps this year ! Greetings all !
I look forward to meeting you,Michael
Moderated by  Gord&Fran
