| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | What is a good way to clean the inside of the horn assembly? I cleaned the contact points last night and they blew like a freight train but was concerned about the light surface rust all around this area and how to keep it from getting worse without damaging the coil and wires? Also what kind of paint will work on the outside? As I think part of these horns is aluminum correct me if I am wrong. Thanks | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | If it's just light surface rust you probably don't need to worry about it. I'm not an expert but under normal usage you shouldn't have a problem.
| | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | Focus, I just did mine the other day. Covering all volnerable parts, I cleaned by blasting gently with some old glassbeads. It came out wonderfully clean and after blowing with some pressure air, it works fine! The outside has been blasted with normal glassbeads and looks wonderfull now! | | |
