5 members (klhansen, mick53, greenie-reddy, Sjm, 1 invisible), 96 guests, and 2 robots.
Topics128,261
Posts1,058,323
Members48,485
#1017625 03/28/2014 4:09 AM
front shackles on 52 truck 1ton. is there 4 cork washers on each side. or does just the bottom get them. thanks any help would be appreciated
It should require 4 washers per shackle. Unless you're doing a correct restoration, they make rubber seals which hold up better.
Bruce
My Trucks
Stuff I Collect
yes i want to do correct restoration. bruce how thick are they. i hope my bolt has enough thread
Hi Jimbo, I recently rebuilt my front end and the rubber seals are 5/16" thick.
thanks guys
Moderated by  Dusty53
