2 members (Waveski, Gib70),
82
Mod | | | Forums66 Topics128,094 Posts1,056,464 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | front shackles on 52 truck 1ton. is there 4 cork washers on each side. or does just the bottom get them. thanks any help would be appreciated | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | It should require 4 washers per shackle. Unless you're doing a correct restoration, they make rubber seals which hold up better.
Bruce
| | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | yes i want to do correct restoration. bruce how thick are they. i hope my bolt has enough thread | | | | | Joined: Jan 2011 Posts: 35 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 35 | Hi Jimbo, I recently rebuilt my front end and the rubber seals are 5/16" thick. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | |
