| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | They posted it on the 67-72 forum too.
I've seen a few Trailblazer Chassis swaps. That was the first SSR. You have to get used to the deep offset wheels, but pretty cool. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's the first time I've seen that swap. They did a good job of incorporating the dash and interior of the SSR into it. The way they cut the front wheelwells just doesn't do the truck justice, though.
I agree with Whitedog, you have to get used to the negative offset wheels. I prefer deep dish wheels, but it's a cool truck. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | This one isn't too bad. It's on a GMC Envoy chassis. I think the SSR chassis is pretty much the same as the TB/Envoys. http://s240.photobucket.com/user/ne...&_suid=13960237347950575566439101961The steelies on that 50 are actually spare tire rims, not my cup of tea.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I thought that too, but I'm wondering if they're just the steel wheels you buy from the tire store for $40 EA for winter tires? Either way they don't suit it. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | They used about 4 different styles of spares on the Trailblazer. That was one of them.
The Trailblazer actually uses the same bolt pattern as the Chevy Venture van. Could be off of a mini-van too.
Those GMC wheel actually look better under that truck, than they do under the Envoys.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I like the floor drain/vent the best.  Isn't that positive offset necessary to fit tire inside wells with the axle widths he used? WMS-WMS.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, it is, but he could use some nicer factory alloy wheels that would complete the look, or even a better looking steel wheel. | | |
