0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1017493 03/27/2014 9:22 PM
The weather is finally letting me get going on my 51 3104, so I figured I'd change the oil and get her lubed up. When I pulled the old oil filter, there's still an inch or so of oil in the canister. It's been a while since I worked on this type filter, but I thought it should all drain down. Is something plugged? I tried to find a drain/return with a piece of stovepipe wire, but no luck. I'm going to sop the oil up with some rags, whats my next step? Thanks. John P.s.: The element is a NAPA 1100 if that helps to clarify.
That is normal
I use a siphon gun to get the remainder out.
...pic...
My canister has a plug at the bottom
...pic...
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by tinnerjohn
....I thought it should all drain down. Is something plugged?....
The hole in your housing that the oil drains through isn't on the bottom of the housing stem, it's an inch or two above the bottom. Momma's turkey baster works well to get the oil out. grin
Duh, now I remember! Thanks for your help guys. It's funny how things you knew 40 years ago can be forgotten. But then I can't remember what I had for supper last night. John
I hope last nights dinner was not turkey at Tiny's house...have you heard what the uses the baster for?
Lots more pictures
Here's another question regarding the canister type oil filters. Since I've never fooled with one of these before I thought I'd ask those of you that have done this many times! Does the oil come into the canister thru the side hose & fitting and then build up in the canister until it flows back thru the small hole in the side of the center tube? Or does it come up thru the center tube & flow back thru the side fitting & hose? In addition, when changing the oil, is it necessary to fill the canister up to the level of the small hole in the center tube in addition to putting oil into the valve cover opening? I have read where it takes 5 quarts (for the crankcase?) and 1 quart (for the canister). Does this seem right
5 quarts in the crankcase and 1 for the filter is correct. Unless you have the large filter like I do then add 1 more for the filter. This might be helpful:
http://farm8.staticflickr.com/7408/9051899682_56309de789_z.jpg
From the canister through the filter and out the center tube. As best as I can tell.
Steve H
Great! Thanks!!
Riding in the Passing Lane
The oil goes in the side & drains out the bottom. You do not have to add oil to the filter. The pump will fill it.
1972 Chevy c10 Cheyenne Super
Steve H, I noticed you said you have a large filter. I recently got a 55.1, 235, with a very large Canister. It’s about 8.5 inches on the side down to the funnel and 5 inch OD. I ended up getting a ”junior” element because I figured all P-115s would be the same. The junior P-115 is significantly shorter and a little bigger in OD. Anyway my question is what is the correct filter element and where do you get them? Thanks.
M. Hayden
