5 members (Hawkman, Peggy M, Otto Skorzeny, BC59, 1 invisible), 178 guests, and 3 robots.
Topics128,078
Posts1,056,057
Members48,433
#1017517 03/27/2014 10:58 PM
Has anyone swapped in a new engine/tranny combo and saved the torque tube? The reason I ask is, the truck has a 2 speed Eaton axle. I don't want to have to change the old 10 lug pattern, new wheels, and so on.
Gric #1017549 03/28/2014 1:08 AM
need to specify the year and model, thought all big bolts had split driveshafts with an open shaft on the rear
Gric #1017550 03/28/2014 1:08 AM
Take another look at what you have. If its an Eaton 2 speed, its an open drive shaft and you can put any motor and transmission in front of it that will fit in your engine compartment.
Gric #1017928 03/29/2014 5:09 AM
It's a 1938 with an Eaton Ruckstell 2speed torque tube. 157.5 wheelbase 2 pc torque tube driveline.
Gric #1017994 03/29/2014 4:37 PM
You've got a real old timer. I'm not sure if a later third member will fit your housing or not. There wasn't much interchangeability in those years. Machining an input housing with a bearing and a seal might be an option to convert it to an open drive shaft.
