| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | Has anyone swapped in a new engine/tranny combo and saved the torque tube? The reason I ask is, the truck has a 2 speed Eaton axle. I don't want to have to change the old 10 lug pattern, new wheels, and so on. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | need to specify the year and model, thought all big bolts had split driveshafts with an open shaft on the rear
Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Take another look at what you have. If its an Eaton 2 speed, its an open drive shaft and you can put any motor and transmission in front of it that will fit in your engine compartment. | | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | It's a 1938 with an Eaton Ruckstell 2speed torque tube. 157.5 wheelbase 2 pc torque tube driveline. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You've got a real old timer. I'm not sure if a later third member will fit your housing or not. There wasn't much interchangeability in those years. Machining an input housing with a bearing and a seal might be an option to convert it to an open drive shaft. | | |
