| | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok guys, whats the very best 6 volt battery i can run in my big bolt?? and how long should it have to idel before its charged fully once its been sittin and jumped? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If you are using a generator, it will never charge up at idle, unless you have a higher than necessary idle speed. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Get the highest amp hour battery you can afford.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | what he said.  | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Depends on your battery box. It's possible to get a 6V battery with more than the Optima's output but they are big batteries. If your battery box is the same size as the smaller trucks by all means the Optima is head & shoulders above the rest.
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | chevk with your local JD dealer...doc | | |
