7 members (Dennys28, klhansen, walter74, Lightholder's Dad, Millenimech, Wayne67vert, 1 invisible), 139 guests, and 4 robots.
Topics128,209
Posts1,057,462
Members48,471
ok guys, whats the very best 6 volt battery i can run in my big bolt?? and how long should it have to idel before its charged fully once its been sittin and jumped?
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
If you are using a generator, it will never charge up at idle, unless you have a higher than necessary idle speed.
Get the highest amp hour battery you can afford.
"It ain't a truck if you can't hose out the cab."
1 Offline
Quote
Originally posted by tclederman:
6v Optima Red Top
800-850 CCA
Optima batteries
This is a good price (including shipping)
what he said. grin
Ex Hall Monitor
Ex Hall Monitor
Depends on your battery box. It's possible to get a 6V battery with more than the Optima's output but they are big batteries. If your battery box is the same size as the smaller trucks by all means the Optima is head & shoulders above the rest.
chevk with your local JD dealer...doc
