2 members (Charles in CA, Otto Skorzeny), 310 guests, and 7 robots.
Topics128,078
Posts1,056,031
Members48,433
#1016700 03/25/2014 7:50 AM
rwb
Offline
anyone swapped a dash from a 55-59 chevy into
55-59 gmc cab?? i am having a hard time finding
a better chevy cab as mine real bad shape. i did find
a stripped gmc cab someone had started years ago
that is in really good shape. but of course has the gmc dash. thanks
What's wrong with the GMC dash?
They have a nicer line to them.... like a 'corvette'!
Give me ambiguity
or give me something else
folks have replaced the TF dash, just a lot of work and needs a lot of care, the top mounting flange of the dash is the lip that mounts the windshield .... there's a pile of spot welds there that have to be carefully drilled out, and a bracket below that reinforces the dash where the steering column mounts that's welded to the firewall
rwb
Offline
didnt really notice that. there was also a 1 1/2 ton
about 1958 that had gauges in the dash think those would fit the 1/2 ton cab ???
all the dashes 55-59 are the same regardless of truck model
