1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | anyone swapped a dash from a 55-59 chevy into 55-59 gmc cab?? i am having a hard time finding a better chevy cab as mine real bad shape. i did find a stripped gmc cab someone had started years ago that is in really good shape. but of course has the gmc dash. thanks
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | What's wrong with the GMC dash? They have a nicer line to them.... like a 'corvette'!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | folks have replaced the TF dash, just a lot of work and needs a lot of care, the top mounting flange of the dash is the lip that mounts the windshield .... there's a pile of spot welds there that have to be carefully drilled out, and a bracket below that reinforces the dash where the steering column mounts that's welded to the firewall
Bill | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | didnt really notice that. there was also a 1 1/2 ton about 1958 that had gauges in the dash think those would fit the 1/2 ton cab ???
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the dashes 55-59 are the same regardless of truck model
Bill | | |
