0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 15 New Guy | | New Guy Joined: May 2005 Posts: 15 | What year did Chev swap to 12 volt systems in their trucks ? I tried researching to see if any of my dads scrap heap might have one with no luck. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think '55 was the beginning of the 12 volt system. Technically, I guess this would be 55/2nd as the earlier model, identified as 55/1st was still 6 volts. I might be damp on this one! Stuart | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe yer still dry. My 55 1st was 6V.
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | 55'TF (2nd) was 1st. year for chevy truck 12volt. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yup, what the others said. The 2nd series came out about March of '55, if you want to pin it even closer. In addition to the trucks, the first 6 or so Corvettes in '55 (the last 6 cylinder models) also were 6 volt.
Bill Burmeister | | | | | Joined: May 2005 Posts: 15 New Guy | | New Guy Joined: May 2005 Posts: 15 | Thanks, im pretty sure he was one quicking around then. | | |
