Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (MickeyP, baldeagle, Gdads51, Hotrod Lincoln, klhansen, KingG), 56 guests, and 0 robots.
Topics128,007
Posts1,055,281
Members48,418
#1015979 03/22/2014 3:15 AM
I just got first 49.. 5 window.I know the question has been ask a hundred times but I needs some help.im trying to find out the year and size of the motor but the block# start with one letter then has 3 numbers an then a letter. I cant find anything that reads like this for a code. Anyone ever see this or hear of how to decode?
My49.5window #1016014 03/22/2014 12:32 PM
Good morning. I'm new around these parts and currently in the discovery phase myself right now.
There are several numbers on the motor. Here is a good example...
Casting number locations
Not shown in the picture above is another number stamped on the flat surface to the left of the distributor. On my truck this number read F1011A. Is that the number you are referring too? If so, try to find your casting block casting number and then reference it here...
Casting number lookup
Once you find the year ranges for that casting number, look at the engine serial number link. That will then show how the numbers on the flat surface map out. The first letter is the plant, the next 2-4 numbers are the month (in my case, Oct 11 (1011)) and the last letter indicates the usage (passenger, truck, etc).
When I first started my research, none of the engine serial numbers matched the year range of the truck (1952). As it turns out, the motor is from 1958-1962 range.
Hope that helps.
Ron and Ryan Hill
1952 Chevy 3100
