1 members (1 invisible),
56
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i want to run a ground from the cab to the frame. a ground from each head lite and turn signal to the frame. a ground from the tail lites to the frame. this is a 53 3600 with a powdercoated frame. new paint on the fenders, cab and skirts.
what size wire should i use for the grounds? oh it's a 12 volt system with alternator. thanks rolf
1963 c10 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | for starters, you don't need individual grounds to each item, a good connection from the battery to the frame, from the same point to the cab, and one to the engine, and one from a rearward frame bolt to the rear cross sill, and you shouldn't have any problems .... the next major point is you'll need to grind off that powder coat where you attach any ground, ground wires need good contact to clean bare metal  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 14-16 Ga. for your second and third type but 4 Ga or braid (usually 4 ga also) for what Bill said and your first type. You can run the grounds if the normal one's Bill states don't work. Main thing, as said, is clean metal and star washer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thank you gentlemen i know all those grounds are overkill but what the heck. can't hurt.
rolf
1963 c10 | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I agree, cant overdo the grounds. Most importantly is that any sheet metal that acts as a ground path needs to be grounded back to the battery. IMHO, Chevy did a terrible job with this. On new painted metal, you are asking for the ground path to be through bolted connections. The fender skirts are the worst offenders. Considering this, the front running lights are supposed to be grounded through the housing, through the grille, through the bolted connections to the fenders, through the fenders to the fender skirts, through the fender skirts to the cab, through the cab to the frame and eventually to the battery. I added a dedicated ground wire from the running lights to the ground point on the fender skirts. I grounded the fender skirts to the frame. For the under dash wiring and accessories, I added a ground buss terminal block and ran a dedicated ground (heavy gauge wire) from the buss to the engine/frame ground strap. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | On my 53 3600 I replaced the two factory grounds: battery to rusty frame then second was rusty frame to nasty bellhousing. Got a new long ground strap from Batt over to side of trans. Don't think there are others on my truck and all electrics are good. Now I'm in the middle of installing a new harness, figure she needs one every 60 years or so. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 |
1963 c10 | | |
