6 members (moparguy, Otto Skorzeny, 2-Ton, lumbersawyer, DadsFirstPickup, Barry Martak), 149 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Hoping to flop in a 1955 rear to my 1950 3100 over the summer with some help on locating it and the brackets. It got me to wonder if there is a manufacturer/aftermarket supplier of a ready to drop in open rear?
Drew
I would guess that curries or one of the other performance places would make one if you gave them the dimensions.
I have a 59 so can't say to much about AD series, but wonder if a 54 or early 55 would just swap in, I may be mistaken but I think they were open drive shafts not torque tube rears.
Tommy
59 apache 1/2t
261 short stepside
You are correct. The '55 I have is an open rear. The biggest thing for me is getting it all located correctly on the spring brackets and getting them welded properly. And you are probably right about Currie.
Drew
The '55 first rear is a bolt in if you use the '55 springs.
Thanks Cletis. I did not know that.
Drew
Strange makes custom 12 bolt axles.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Why don't you just lock up the spring pivots on the axle and
drop a later open carrier into your housing. Lots of options
available then.
DG
Denny G
Sandwich, IL
Thanks for that suggestion. Something to think about.
Drew
