1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#755062 06/16/2011 5:06 PM
Anyone know where I can get the tool for adjusting the drum brakes on my 54 chevy truck?
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
a flat screwdriver will do it if you can't find the tool at the local parts store.
They should have these in the stores.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks Guys
Jimmi V.
Since my question is similar I thought I would add to this post.
I too need and adjustment tool and it might be a good idea to get a pair of those big pliers to put the springs on too. I would like to get snap-on brand because...well because I like tools. I can find the tools on ebay but I am not sure what snap on part number is correct (1955 first series). If someone has the snap-on tools and they work on the Stovebolt brakes could you kindly post the part numbers?
Joe
1955 First Series 3100
Here you go.
http://store.snapon.com/Brake-Spring-Tools-Pliers-Brake-Spring-P636104.aspx
Here is a listing of all the brake service tools that Snap On has listed in their catalog.
http://store.snapon.com/BRAKE-SERVICE-TOOLS-C629122.aspx
Sir Searchalot
Sir Searchalot
As much as I like the tools, and I do. My tool box has become home to a few home made items and the "brake" adjuster is one of them. I put an old screw driver into the hole for a trailer ball and leaned on it. Instant brake adjuster. Cost? 0$ still in there and working for 20 years. The rest of the set of screw drivers that it came with are long gone.
Steve H
They make all kinds of bends on the adjusting spoons. I distinctly remember that the tool that worked on my 56 Ford passenger car would not work on a 3/4 ton GMC with overload springs. And back in those days, adjusting brakes was part of a routine oil and grease job which often came once a week. I have at least a dozen spoons in my old tool box, but I don't remember what worked on what.
Moderated by  MNSmith
