1 members (Gray_Ghost),
83
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Anyone know where I can get the tool for adjusting the drum brakes on my 54 chevy truck? Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | a flat screwdriver will do it if you can't find the tool at the local parts store. They should have these in the stores.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Since my question is similar I thought I would add to this post.
I too need and adjustment tool and it might be a good idea to get a pair of those big pliers to put the springs on too. I would like to get snap-on brand because...well because I like tools. I can find the tools on ebay but I am not sure what snap on part number is correct (1955 first series). If someone has the snap-on tools and they work on the Stovebolt brakes could you kindly post the part numbers?
Joe
1955 First Series 3100
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | As much as I like the tools, and I do. My tool box has become home to a few home made items and the "brake" adjuster is one of them. I put an old screw driver into the hole for a trailer ball and leaned on it. Instant brake adjuster. Cost? 0$ still in there and working for 20 years. The rest of the set of screw drivers that it came with are long gone.
Steve H
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | They make all kinds of bends on the adjusting spoons. I distinctly remember that the tool that worked on my 56 Ford passenger car would not work on a 3/4 ton GMC with overload springs. And back in those days, adjusting brakes was part of a routine oil and grease job which often came once a week. I have at least a dozen spoons in my old tool box, but I don't remember what worked on what. | | |
