2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | I know the sm420 is strong but is it big torque strong? I am curious cause I would love to have the sm420 back in my 1ton instead of the th400. The adapter kit with clutch total 500$. But I don't want to destroy anything. My big block buick is producing over 500 lbs of torque over a wide early rpm. Peaking at over 550. Edit... just realized should have posted in driveline section.... sorry.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | The rock crawler crowd loves the 420 for a lot of the games they play. We also used them in the super stock truck classes in the tractor pulling game, and I don't remember too many hand grenaded transmissions. Unless you're running big slicks and treating every stoplight like a drag strip, there shouldn't be any problems. Jerry
| | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Another option is the SM465. It may be a little easier to find. Would probably require the same install kit.
The 1st gear isn't quite as low, 6.5:1 vs. 7:1, but no sense in splitting hairs.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The SM465 takes a different bellhousing, it has a larger bearing retainer. | | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | According to the kit it says it fits sm420/sm465. I have an sm420 now. My motor is not set up for manual trans yet anyways. For now , until funds are raised, th400 will be used I think, if i can get a torque converter here soon. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Have you thought about a hydraulic pedal?
Wilwood has a nice pedal setup. For the throwout you could use a bellhousing and slave cylinder from a mid 80's truck or, a bearing retainer mount style.
The Chevy Colorado used a slave that mounted on the bearing retainer, it may be adaptable to other transmissions.
It would be a heck of alot cheaper than the kits that are out there.
