1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#101483 07/05/2007 12:55 AM
V
V Offline
I want to ask you all what you all do about the floor mat, battery box cover and jump starting or charging the truck battery. I've already found I do not like removing the screws along the edge of the door/floor to gain access to the battery box cover. It seems like there has to be a better set up than taking out the screws and lifting the jute and rubber floor mat. Anyone have remote terminals or a method to charge the battery that doesn't require screw removal and floor mat lifting? As always, thanks and I know you all have been at this a lot longer than me.
#101484 07/05/2007 1:37 AM
on my engine i just let the mat lay on top of the battery box lid. i just fold the mat back when i need to gain access. same goes for the M/C
#101485 07/05/2007 1:45 AM
V
V Offline
How do you secure the rubber mat on the floor?
#101486 07/05/2007 1:47 AM
Mount a one of these in a convenient location in the engine compartment...OR, mount both positive and negative of this item side by side in the engine compartment. Just run appropriate cables from the stud to the battery, then when you need to jump, pop the hood and attach the cables to the color coded posts.
http://pollak.thomasnet.com/viewite.../battery-jumper-terminals?&forward=1
Stuart
#101487 07/05/2007 2:00 AM
Mount a drop down battery box in the stock location.
#101488 07/05/2007 2:15 AM
VirginiaFireTuck, just open hood and put the positive to the starter and ground anywhere to the engine or frame. The positive cable from the battery goes to the starter so, why remove the floormat to get to the battery? Here is a pic of the drivers side of my floormat, the passenger is just the opposite. P.S. You can do the same with a battery charger.
Another good recommendation, get a Optima battery, it will fit just perfect on a diagonal in your battey tray (6 volt that is)! And, they are great batteries!!
#101489 07/05/2007 3:06 AM
V
V Offline
Thanks everyone. Good ideas.
AD_Pickup: I guess I never thought of using that method. You are correct. BTW: my floor mat set up looks identical to yours. I think I'll screw the mat back down and try your method. Why make it harder than it needs to be? Keep it simple...
You all are the best! Thanks again.
