| | | Forums66 Topics128,204 Posts1,057,289 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 12 New Guy | | New Guy Joined: Nov 2013 Posts: 12 | Hi, I need to pull and replace the carrier bearing, once the rear section of the shaft is out, how do I remove the yoke in the middle, to remove the carrier and replace the bearing? it appears to be a spline sleeve but my manual makes it appear there is a threaded connecter also? can anyone explain it? so I don't ruin it thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny Graham will know you should check his pictures. | | | | | Joined: Nov 2013 Posts: 12 New Guy | | New Guy Joined: Nov 2013 Posts: 12 | | | | | | Joined: Sep 2013 Posts: 36 New Guy | | New Guy Joined: Sep 2013 Posts: 36 | Very easy job. Unbolt the yoke, and remove from the tube, you might as well replace the donut while you are at it, as they cost pennys.
Once that is stripped, you might be lucky and the shaft will just drop out, if not a bearing splitter will be required, or a press to push the shaft out. Once out remove bearing and oil seal and fit new. Rebuild. Simple really. | | |
