6 members (Hambone, Gdads51, dt235sd, papas52, Bruce 1954-4100, tclederman), 129 guests, and 2 robots.
Topics128,111
Posts1,056,258
Members48,437
#1014054 03/14/2014 1:31 AM
1954 Chevy 3100
http://imgur.com/YcZe5Fc
I bought a painless wiring harness and am attempting to hook up the turn signal switch.
I used this wiring diagram:
http://i292.photobucket.com/albums/mm24/winowally/Truck%20%20Parts/TurnSignals.jpg
But it is not working properly. Need help.
Here is the wiring diagram for the new wiring harness:
[See 'Steering Column Connector' on page3]
http://www.dreamershotrods.com/images/american/instructions/500467_Instructions.pdf
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
Might help to know what kind of problem you are having. Is part of the lights working? Wrong light working? Nothing working at all?
I have power coming from the brake switch when brakes are pressed. I imagine the red wire, going into the switch, is the power that feeds everything. What I need to know is which wire is the left/right turn signal and which is the brake lights. By which wires, I mean on the switch itself. I have 6 colors: orange, red, green, black, yellow, and brown.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Just a thought right now, ill hook up the red wire and see what gets power when I change the blinkers and brakes... nvm yall...
DJ __|__
--O-(_)-O--
'54 Chevy 3100
soldering on that switch looks suspect, possible cold joints .... compare that generic wiring diagram with the info in the tech tip
I got it working.
The right blinker is blinking slower and dimmer than the left side. Any suggestions?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
I bought a flasher from one of the old chevy parts dealers. I figured out after the second one they were junk. Paid about 8.00. Then bought a borg warner for 20.00 and they work great.
Sir Searchalot
Sir Searchalot
Blinking slower, dimmer? Ground or hot contact corroded/loose somewhere. Could be problem inside the switch.
Slower and dimmer on one side can be caused by a bad connection. Either hot or a bad ground. If those check out then look at the light bulbs and make sure they match what is in the working side. A low watt bulb will draw less current than a higher watt bulb and the flasher is current sensitive. A single low watt bulb will dim and slow the lights on one side. Let us know what you find.
Steve H
I was having slow and inconsistent blinking and it was the flasher.
