Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1014126 03/14/2014 9:41 AM
Hey All,
1955, 2nd series, 3100, Napco, 283, 4 speed trans. My speedometer is off by 10 mph. ie-45mph=55mph. I removed the speedometer cable from the gear assembly at the trans, then pulled the assembly out of the trans thinking I could replace the gear. The assembly is a solid unit, all steel.
Do they make a unit (Part that would fit between the gear assembly and speedometer cable) to slow down or speed up the speedometer? I seem to remember an apperatous on my 1983 Chevy pickup and some F%#ds of about the same year that fit between the gear and cable. I am also probably running to large of tire but do not want to purchase new tires.
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
ODSS Lawman
ODSS Lawman
Is everything stock on the truck? Tire size etc? If yes, do a good inspection of all parts for wear.
If all checks out, you can get an adapter that fits between the speedo cable and the transmission. I purchased mine from Scott's speedometer for about $80 several years ago.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
A large tire will make the speedo read too low. I have a speedo adapter that is designed to reduce the speed and would be used if the speedo was reading too high, not too low. You can find different ones on eBay. Mine is by Stuart Warner and stamped 0.73333 so it reduces speedo reading by 26%. I'm not sure, but it sounds like your speedo reads too low. That's what my mini truck does because I'm running larger diameter tires than stock.
I don't know what the thread on your trans is, but would one of the adapters on THIS PAGE listed under GM DODGE FORD RATIO ADAPTERS work for you?
My 46 GMC on Photobucket
Thanks guys!!! I will check out all information and advice!!!
Stranger
Frank in Iowa
"Mater's Cousin"
If your speedometer is off by 10 mph at all speeds, you have an offset error. In that case an adapter won't help. If it is off by changing amounts at different speeds than an adapter will help. I would suggest that you graph the two sets of readings, real and displayed on a piece of paper and then you can see what you have.
1951 1 Ton Completed
I had a similar problem when I changed my rear end gears and went with larger tires, so I bought an adapter from Jim Carter. Works great...easy to install. Here is the link--
http://www.oldchevytrucks.com/cart/product.asp?prodid=SP249&i=9939|||||
Maybe this is easier to link to. Adapter Jim Carter
