| | | Forums66 Topics128,102 Posts1,056,533 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 6 New Guy | | New Guy Joined: Feb 2014 Posts: 6 | I'm looking at one of those 292 replacement exhaust manifolds from THE Company in Iowa. It doesn't have a heat riser. I am planning to put it on a 250 that I use for a daily driver. Will I have any problems with that or could I drill it and put a heat riser out of another manifold in it? I'm a newbie to this forum and really appreciate the expertise of you veterans! Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It would be pretty hard to install a heat rizor in a manifold without one. The 292 & 250 manifolds are interchangeable. The heavy duty manifolds that are used on the 1 1/2 ton & larger 292 trucks did not come with one. It has a 2 1/2 in. opening & points straight down. Is a new one available with the heat rizor in it? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2014 Posts: 6 New Guy | | New Guy Joined: Feb 2014 Posts: 6 | I haven't been able to find one of the new ones with a heat riser in it. The new one that is sold by THE Company in Iowa doesn't have a heat riser in it. I'd pickup a used one with a heat riser, but I don't know where to find one. I'm worried that without a heat riser you might overheat the intake manifold eventually? | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | You could install a stainless steel plate with only a small opening between the two manifolds. It would heat but still limit how much. I doubt it would over heat, the valves don't seal 100%, not even 75%, it directs the exhaust down and out more then seal off the intake.
Joe | | | | | Joined: Feb 2014 Posts: 6 New Guy | | New Guy Joined: Feb 2014 Posts: 6 | [quote=Joe H]You could install a stainless steel plate with only a small opening between the two manifolds. It would heat but still limit how much. I doubt it would over heat, the valves don't seal 100%, not even 75%, it directs the exhaust down and out more then seal off the intake.
Joe [/quote] That sounds like a good idea. Maybe I could drill a few holes - 3'8"? - in the plate. I'm looking for something that will heat up faster when the engine is cold than the plates that are made to circulate radiator coolant under the intake manifold. Do you think I would have to have some machining done to one or both manifolds (the thickness of the alum plate) so they would still align and seal to the head? | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Mikie, Out of curiosity, what is the part number of the manifold you're looking at from THE company? Thanks.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | Some of the gasket sets come with a block off gasket, it has steel on side. I have used them in the past, but they always seemed to be burnt through when I remove them.
18 to 25 gauge (.050" to .0219" ) would work with out altering the manifolds. I have had to use two gaskets to get a old manifold to seal with out problems. You may have to buy a new gasket, then cut in apart to sandwich the stainless steel.
Intake Manifold to Exhaust Manifold Gasket Part Number: FPG 9763 Product Line: FEL-PRO Gaskets
Part # MS9786 Full set including solid gasket.
Joe | | | | | Joined: Feb 2014 Posts: 6 New Guy | | New Guy Joined: Feb 2014 Posts: 6 | Thanks for your reply Joe. I talked to a retired GM engineer this weekend and he said that without a heat riser valve directing the exhaust gasses up towards the intake manifold, the gasses just kind of "drift" up there a little bit.That kind of sounds like my worries about it getting the intake too hot might be unlikely. Maybe you can just leave that passageway open? | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | You sure can. if you look close at the valve, you will see it doesn't do much at all in sealing off the intake, its just a diverter to get the exh out of the manifold better.
Joe | | |
