7 members (55shaker, KEVINSKI, TUTS 59, Otto Skorzeny, Lostbuthaulinass, 32Fordpuchoptop, moparguy),
107
Mod | | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | Does anyone have a (reasonably) simple method for bench testing a 0-30# oil pressure gauge? :confused: I'd like to know that it will move but also make sure it is somewhat accurate. Thanks! | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | db'51
Haven't done this but have you tried connecting a line from your air compressor to the back of the gauge.
Make sure you have a good regulator and pressure gauge inbetween the gauge and the compressor.
Pressure is pressure as long as you don't go above 30 psi you shouldn't have a problem.
If you try it let us know how it works for you.
Gary, Kelly, and Family
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I tested my heater, I used a couple of chunks of heater hose, slipped tire valves, the rubber end into the hoses and used gear clamps on them. The other ends were hooked up to the heater. I was able to use a bicycle pump to provide pressure and then immerse the whole thing in water. If you can make a tire the source of your air pressure, you can set the tire for whatever pressure you want and use a similar setup. | | |
