0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | Can someone give me the resistive readings for a 55 2nd series gas gauge sending unit. Start with empty and go to full. Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | robert giles,
A '55/2 sending unit should be a 30 ohm unit. I believe your resistance measurement would be 30 ohms with the float at FULL and 0 ohms with the float dropped all the way down to simulate EMPTY. I could very easily have this bass-ackwards, but a quick test with your ohmmeter will tell the tale. Any midpoint reading will be somewhere between 0 and 30 ohms!
It sounds like this might be too vague for you. If you get the 0 and 30 ohm readings, the little wire wound resistor is contiguous and should read properly at any fuel level.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | continuous Stuart! but yer right, zero empty [or close, usually 1-3 ohms], 30 full .... in between, who cares? the gauges are rarely accurate anyway Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill, Are you jerking my chain buster!  Merriam-Webster gives us folks from California this 'daffynition' for contiguous. 'touching or connected throughout in an unbroken sequence' I was trying to say that as long as the little wire wasn't broken somewhere in its travels, the gauge should read properly....the wire is contiguous. Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well it might be touching right close upside the tube, but that don't mean it's continuous! continuity: ' uninterrupted connection, succession, or union' ..... as in electrical continuity Bill | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Stuart,
Maybe only Muricans know the term due to having some non-contiguous states. Those provincials to the north are unfamiliar with the concept;-) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey you! Canada and the US are contiguous, but try crossin the line and you learn they're not continuous! Bill | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Unless you have a Mullet..Then they are continouous...... Def.of Mullet: Canadian Passport
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | Thanks for the information and the english lesson. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | AAH HAH The Lurking HOUSE PAINTER..... LOL MUH HHHAAAAHHAHHH Love ya Brother, regards | | |
