Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, 2-Ton, 2 invisible), 47 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#101339 06/28/2007 1:12 AM
Can someone give me the resistive readings for a 55 2nd series gas gauge sending unit. Start with empty and go to full.
#101340 06/28/2007 2:15 AM
robert giles,
A '55/2 sending unit should be a 30 ohm unit. I believe your resistance measurement would be 30 ohms with the float at FULL and 0 ohms with the float dropped all the way down to simulate EMPTY. I could very easily have this bass-ackwards, but a quick test with your ohmmeter will tell the tale. Any midpoint reading will be somewhere between 0 and 30 ohms!
It sounds like this might be too vague for you. If you get the 0 and 30 ohm readings, the little wire wound resistor is contiguous and should read properly at any fuel level.
Stuart
#101341 06/28/2007 2:24 AM
continuous Stuart! grin
but yer right, zero empty [or close, usually 1-3 ohms], 30 full .... in between, who cares? the gauges are rarely accurate anyway ohwell
#101342 06/28/2007 4:03 AM
Bill,
Are you jerking my chain buster! grin Merriam-Webster gives us folks from California this 'daffynition' for contiguous.
'touching or connected throughout in an unbroken sequence'
I was trying to say that as long as the little wire wasn't broken somewhere in its travels, the gauge should read properly....the wire is contiguous. smile
Stuart
#101343 06/28/2007 4:57 AM
well it might be touching right close upside the tube, but that don't mean it's continuous!
continuity: ' uninterrupted connection, succession, or union' ..... as in electrical continuity grin
#101344 06/28/2007 5:01 AM
Stuart,
Maybe only Muricans know the term due to having some non-contiguous states. Those provincials to the north are unfamiliar with the concept;-)
#101345 06/28/2007 6:06 AM
hey you! Canada and the US are contiguous, but try crossin the line and you learn they're not continuous! grin
#101346 06/28/2007 12:53 PM
Unless you have a Mullet..Then they are continouous...... wink
Def.of Mullet: Canadian Passport
HURRY UP AND WAIT 55 235 3/4
#101347 06/28/2007 4:57 PM
Thanks for the information and the english lesson.
#101348 06/29/2007 8:08 PM
AAH HAH
The Lurking HOUSE PAINTER.....
LOL
MUH HHHAAAAHHAHHH
Love ya Brother,
regards
