0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#1013152 03/10/2014 5:42 AM
I'm new to the forum and am looking at buying what is listed as a 53 1/2 ton, however, it's a dually flatbed. I'm thinking it has to be at least a 1 ton. The person selling the truck said there's no vin plate. It also has a hood that has "3100" on it. I'm thinking it was switches out at some point. Any suggestions as to finding out exactly what this is?
thank you,
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
If it is truly a 3100 hood, the truck most likely is a 3/4 ton or 1 ton. the hoods are larger on the big bolts. How many wheel lugs? Make sure that the identification serial/tag is on the drivers door pillar. …………g
JoeR #1013179 03/10/2014 11:36 AM
So a 3/4 and a 1 Ton would have 8 lug wheels, as mentioned above. The frame over the rear wheels would have a slight kickup on a 3/4 and would be straight on a 1 Ton.
1951 1 Ton Completed
Dual wheels are very uncommon on a 3/4 ton.
Another thing to check is 1 ton should be 137" wheelbase and anything shorter would be 3/4 or possibly 1/2 ton.
If the 3100 hood was swapped (and not just the emblems) then my guess is a 1 ton, assuming 8 lugs. Because the hood won't swap to a larger truck and a dual wheel 3/4 ton is uncommon.
If 10 lug rear then it's 1.5 or 2 ton and someone put 3100 emblems on the truck.
•1952 Chevrolet 3800 pickup
---All pictures---
Pictures would help us help you. I have owned one (see picture) and have seen quite a few of the 1-tons duals equipped with the steel wheel type you see on the stake bed and the rears. Just an observation of a common theme.
https://www.flickr.com/photos/advance-design_parts_co/8130508549/in/set-72157631870734114
The 8 hand hole dual wheels as shown are a dead giveaway for an AD 1 ton truck. They'll be 18" wheels.
---All pictures---
Measure the front spring width. 1.75" is 3/4 ton and 2" is 1 ton.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Make sure all the paper work is in order and matched to the trucks features. Sounds fishy to me.
thank you,
Joe
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Moderated by  Dusty53
