1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
I
I Offline
I want to remove the speedometer drive gear to put it on a different u-joint. Does anyone know how to get the gear off? Or where to get a drive gear? 1940 1/2 ton 4 speed.
When GM sold them,the gear was part # 602798 and fit various 1937-1946 1/2 ton trucks with 4 speeds.
You could contact these people & see if they can help you with your search. Make sure the spiral gear that drives the speedometer gear is OK or you could destroy another gear.
Drive Gears
Speedometer gear
Good luck,
Harold
Harold
I use a bearing splitter and my press to remove the gear.
My Blog
Same here Dave, has to be very fine edge on the chamfer though.
http://www.pbase.com/dennygraham/image/148876672
DG
Denny G
Sandwich, IL
