1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I want to remove the speedometer drive gear to put it on a different u-joint. Does anyone know how to get the gear off? Or where to get a drive gear? 1940 1/2 ton 4 speed. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | When GM sold them,the gear was part # 602798 and fit various 1937-1946 1/2 ton trucks with 4 speeds. You could contact these people & see if they can help you with your search. Make sure the spiral gear that drives the speedometer gear is OK or you could destroy another gear. Drive Gears Speedometer gear Good luck, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Does anyone know how to get the gear off? I use a bearing splitter and my press to remove the gear.
See the USA in your vintage Chevrolet! My Blog | | |
