| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 | Hey guys
I searched brothers 47-54 truck no luck for the frame that holds fenders together and radiator
Where can i find a new one and how much you thonk?
1938 Chevy 1/2 ton Pickup 1940 Chevy 3/4 KD Pickup 1946 Chevy 3/4 ton pickup 1940 Chevy 1/2 KC Pickup 1939 Chevy 1.5 Truck
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Classicparts.com Item #78-518 for 269.95.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And Brad, we should tell him that it's commonly referred to as a radiator core support. Wonder why they don't include the upper cross bar with that reproduction? It's originally spot welded to the sides.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Your right Denny and I probably should encourage posting in the Swap Meet area for one Dino. I think you can do much better than that and have the good original parts to boot! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bet you're wishin' you had saved some of those core supports from your junkers. DG
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I still have a couple sets! | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Just saw a core support on ebay for what may be a reasonable price . Depends on how fast you need it. Also may want to check with chevy truck parts suppliers as some also sell used parts. How about junk yards in your area? Some may offer a service to get one for you.
Ed
