7 members (59 fleet, Wally / Montana, Brian Moore, KCMongo, Otto Skorzeny, Rusty Heaps, mo2cyl),
106
Mod | | | Forums66 Topics128,034 Posts1,055,539 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | I have a 36 1/2 ton and I have heard that the gear box can be swapped out for a 41-46. How much of a steering improvement will this achieve? Enough to go through with it or not really? Thanks for advice Cheers | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got a 37 1/2 ton and did the swap. It is much better due to the recirculating ball bearing mechanism. I think the 36 has the eccentric mechanism on the steering box, as does the 37, and is great to be rid of that item allowing the 41-46 model box to operate like a later model steering box on your truck.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | I swapped mine too, I think it made a big difference. It's not power steering easy by any means, but much easier then the stock gear box. To keep the '37 steering wheel, I cut the shaft on both boxes and welded the '37 top to the '41 lower section. If you choose to keep the '41 steering wheel, you may find the wheel offset a little to deep. This placed the rim of the wheel a little closer to you gut. All in all, it's still worth the trouble.
Joe | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | Thank you. So I guess I would have to cut and weld the shaft for my year as well in order to use same steering wheel? No difference on a 36 high cab compared to 37 in this instance? Cheers | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Wait a minute.....is your's a high cab or a low cab? If it's a high cab, I don't think I would be comfortable telling you that this can be done. I would recommend this for a second series low cab only.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Unfortunately, I cannot answer your question with certainty. I am not that familiar with the high cab 36's. The only reason I can answer some questions about the low cab 36 is because I once had one and I have a 37, which is very similar. Maybe someone else can jump in here.
