4 members (HandyAndy, '37 barn find, cmayna, ESum), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
I have a 40 chevy truck, the crossmember brackets are in a upward angle therefore preventing the rack and pinion from clearing the font motor radiator support. I want to use a 235 so i dont want to cut the support. Does anyone make the brackets to mount the rack and pinion?
1 Offline
You can try companies that make IFS kits like Fatman's or Heidt's or others.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
What brand of front suspension are you using? I'd suggest contacting the manufacturer for the proper equipment to match your vehicle/engine combination. Please tell us you're not trying to use a R&P on an original straight axle! That's Russian Roulette!
No limit sells them. Don't know who else. You have to drill holes through your axle beam to mount them. Then it uses a collapsable steering column for up and down movement.
http://www.nolimit.net/products#!/~/product/category=6257097&id=29062181
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
We can't reliably answer this without knowing what your front suspension setup is.
My 46 GMC on Photobucket
Sorry, Mustang 2. No axle beam, crossmember
Whose Mustang II kit is it?
And loading all 6!
Bill Burmeister
check with fatman fab
