10 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, 2 invisible),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I have a 40 chevy truck, the crossmember brackets are in a upward angle therefore preventing the rack and pinion from clearing the font motor radiator support. I want to use a 235 so i dont want to cut the support. Does anyone make the brackets to mount the rack and pinion? | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | You can try companies that make IFS kits like Fatman's or Heidt's or others.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | What brand of front suspension are you using? I'd suggest contacting the manufacturer for the proper equipment to match your vehicle/engine combination. Please tell us you're not trying to use a R&P on an original straight axle! That's Russian Roulette! Jerry
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | No limit sells them. Don't know who else. You have to drill holes through your axle beam to mount them. Then it uses a collapsable steering column for up and down movement. http://www.nolimit.net/products#!/~/product/category=6257097&id=29062181 http://www.nolimit.net/
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | We can't reliably answer this without knowing what your front suspension setup is. | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | Sorry, Mustang 2. No axle beam, crossmember | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Whose Mustang II kit is it? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Please tell us you're not trying to use a R&P on an original straight axle! That's Russian Roulette! Jerry And loading all 6!
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | | | |
