| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I told many a Stovebolter that I did not want to meet either the steering shaft/ wheel nor the dash if they decided to stop faster than my body. I promised myself 3 point seat belts last summer. Spring has to be coming shortly. I looked into the tech tips and searched for 3 point seat belts and came up empty. Mine will go into my 1951 Chevy 1 ton cab. Can anyone help me out please? Thank You Jerry Jerry
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Deve posted this tech tip on Juliano's. I started the install so I can not tell how well it works.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yep, Juliano's is your best bet. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I also saw 3 pt belts in my new Patrick's catalog. They're old school so have to order the catalog....also lot's of good driveline parts.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I also went with Juliano's. Lots of welding/fabrication is required, so be prepared.
Also, to avoid the chances of your truck stopping faster than your body, may I suggest front disk brakes, and a dual master cylinder. Seatbelts and brakes were the mandatory improvements before anyone in my family would feel somewhat safe driving the truck.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Deve, Thank you for the tutorial, I looked at it this morning and printed it out. I will probably order the appropriate seat belts this week and make this my next project. Again Thank You Jerry Jerry
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I too used the Juliano's 3 point belts in my 52 GMC and 50 Chevy trucks but did not feel comfortable in snaking the fixed part of the system through the seat cushions and came up with a more direct "pull" by using some angle iron brackets mounted to the floor. bracket I had to cut out a piece of the back of the seat frame for the belt to pass through and used pieces of a plastic binder spline as an anti-chafe guard. cutout While I welded in my upper attachment point for the over-the-shoulder attachment point I don't think it is absolutely necessary as the plate is also held in place with a bolt. I think all that would be necessary is to secure it temporarily until that bolt is in place. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | That sounds like a great idea Huck! That's what is so cool about this forum.. you start with an idea, and others make it even better. :) | | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | I just installed a set in my 53, My set came without a mount for the shoulder. I used a 3x3 3/16" steel plate. I drilled a 1/2" hole in the center and two 1/8" holes along one edge for attaching a fish wire. On the back I welded a 7/16 fine thread nut for the attachment bolt. After drilling through the body with a 1/2 drill I dropped the nut assembly down using the wire. A magnet will hold it flat while you start the bolt. I used a dab of silicone on the face of the steel to hold it in place if I ever remove the nut again. No problem with the nut spinning since I had th wire attached. After assembly was complete I jiggled the wire back and forth a bit and snapped it off. | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Will be putting belts in me 57 1/2 ton. any issues with still having the gas tank behind the seat? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | any issues with still having the gas tank behind the seat? Not unless you have it in a movie. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I need to install 3 point seat belts in my 52' 3 window and was wondering how far back I can install the top shoulder harness. My aftermarket seat sits back a little further into the cab corners, so I'd like to have the top mount back in the curved part of the cab. I plan to use a heavy backing plate behind the cab wall with a grade 5 bolt. Will this work? Dck54, do you have any pics of your install? | | |
