4 members (Otto Skorzeny, Hotrod Lincoln, 32Fordpuchoptop, Nhluvstruck), 164 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
8
8 Offline
While rebuilding my Rochester B carb which I believe is original to my '48 235ci Loadmaster. I noticed my Power piston is a little chewed up on the end.
Should I just sand the radius smooth and clean up the V? Or should I find one in better condition?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Rochester 'B' wasn't released till the '50 model year Curt.
You must have a later 235 in your truck. That power piston
is a critical part to the performance of that carburetor on
your engine and is held to a fairly close fit since it's a
vacuum operated device. I don't see anything wrong with that
one from the angle that it's shot at. Just be carful when
cleaning it, you don't want to reduce the clearance and it
must be straight as it pushes the ball off it's seat.
DG
Denny G
Sandwich, IL
I think Curt is talking about the needle end which appears to be a little chewed up. If that is the case then it should be replaced.
1951 1 Ton Completed
Ah, couldn't see it in the picture Fred, yeah think I'd look for
a new one also. If the end is buggered up it's possible the PO
could have hacked some length off of it.
DG
Denny G
Sandwich, IL
8
8 Offline
Sorry guys I should have used a photo like this.
Curt Warren
Salt Lake City
