4 members (Lightholder's Dad, Gray_Ghost, TUTS 59, Wally / Montana), 185 guests, and 2 robots.
Topics128,077
Posts1,056,019
Members48,433
I just recieved my NEW style bracket from Classic Parts to covert my 51 to a dual master. I was surprised to see the new style positions the MC much farther back thus requiring a new hole in the floor for filling. Classic Parts said CPP changed the design. Does anyone know where I might get the previous style that puts the MC closer to the pedal pivot or is this new bracket the way to go? ( the picture on page 73 of the Classic Parts cat. is the old style but they say it is no longer available)
CPP says it is the only one now. I installed it. Having been an engineer for 30 years I can say whoever designed this new bracket should be fired.
ODSS President
ODSS President
Contact Ghostrider here on the Stovebolt. I bought one of his, it's excellent.
~ Cosmo
1949 Chevy Half Ton
The CPP bracket I bought several years ago had to be cut apart and re-welded to make it fit the frame.
Bondo Artiste
Bondo Artiste
I have installed two of the cpp brackets without issue.
~ Phillip
Sir Searchalot
Sir Searchalot
They are using the same bracket for with or without booster. With booster would move it back even further. I don't know how you would fill a dual thru an original floor hole anyway? The old bracket for TF required a hole in floor to be cut. They sell a filler bottle with a hook nose on it to fill from underneath.
I hope you did not get the passenger car bracket, it is loooooooong.
I have one of ghostriders as well..great stuff
Thanks for your input. It just seems unnecessary to have it back so far that one port is over the middle crossmember making it difficult to do the plumbing. I may modify it to move it forward.Just welding an extra length on the back to provide another mounting hole should do it.
Gas Pumper
Gas Pumper
The CPP bracket for the dual MC I have, not using a booster, fits very smoothly between the two crossmembers without any interference. It puts the dual MC pretty close to the same place the old one was.. it IS further back and more towards the tranny, but very close. Its the latest bracket, so not sure unless you have a booster. Then it makes sense. Why I decided to roll the dice and see if my lead foot can stop the truck without a booster.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
