8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | I just recieved my NEW style bracket from Classic Parts to covert my 51 to a dual master. I was surprised to see the new style positions the MC much farther back thus requiring a new hole in the floor for filling. Classic Parts said CPP changed the design. Does anyone know where I might get the previous style that puts the MC closer to the pedal pivot or is this new bracket the way to go? ( the picture on page 73 of the Classic Parts cat. is the old style but they say it is no longer available) Thanks | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | CPP says it is the only one now. I installed it. Having been an engineer for 30 years I can say whoever designed this new bracket should be fired. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Contact Ghostrider here on the Stovebolt. I bought one of his, it's excellent.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The CPP bracket I bought several years ago had to be cut apart and re-welded to make it fit the frame. | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I have installed two of the cpp brackets without issue.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | They are using the same bracket for with or without booster. With booster would move it back even further. I don't know how you would fill a dual thru an original floor hole anyway? The old bracket for TF required a hole in floor to be cut. They sell a filler bottle with a hook nose on it to fill from underneath. I hope you did not get the passenger car bracket, it is loooooooong.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I have one of ghostriders as well..great stuff | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thanks for your input. It just seems unnecessary to have it back so far that one port is over the middle crossmember making it difficult to do the plumbing. I may modify it to move it forward.Just welding an extra length on the back to provide another mounting hole should do it. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The CPP bracket for the dual MC I have, not using a booster, fits very smoothly between the two crossmembers without any interference. It puts the dual MC pretty close to the same place the old one was.. it IS further back and more towards the tranny, but very close. Its the latest bracket, so not sure unless you have a booster. Then it makes sense. Why I decided to roll the dice and see if my lead foot can stop the truck without a booster. | | |
