3 members (MickeyP, Joe H, Jon G),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Is there an easy way to clean the dash light control on my '53 GMC (OE)?
1953 GMC half-ton
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | GMC53, I am not familiar with this light switch. A conventional wire wound rheostat has the wire embedded in a ceramic housing and a shaft of some sort with a wiper attached. The surface between wiper and wound wire becomes scaled and cruddy. Sometimes the heat generated by the wire itself will destroy the tension in the spring that holds the wiper against the wire. Cleaning the mating surfaces with some fine sandpaper can often restore the connection. Put a little piece of 320 grit paper under the wiper and run it through the range a few times. Make sure the wiper pushes against the wire. If this isn't how your switch is constructed, disregard this blurb. Stuart | | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Thanks Stuart, that was just the info I was looking for. Craig
1953 GMC half-ton
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Maybe a spray electrical cleaner would work better?? | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | I've used a pencil eraser to clean the wire part of the rheostat. Just rub it a few time until the wire shines, the eraser usually turns black from all the oxidation it removed.
Gary, Kelly, and Family
| | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I've been to a vintage audio site, and the resto guys there use a metal contact deoxidizer called DEOXIT or DeOxIt or Deoxit. I believe Radio Shack carries it. I've never used it, but the posts say that to remove the oxidation from the contact surfaces you spray a very little cleaner on the reostat and wiper then rub them against each other as they would in normal operation for a few dozen or more times. It seems like it would be better than harsh mechanical removal.
Never start vast projects with half vast ideas.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Retread,
I agree with you. My only thought would be that the pots in a radio would be very fine wire wound devices while the rheostat in a automotive dimmer switch or heater fan control switch would be big old coarse wound fatties that get red hot and crusty. The item you mentioned along with the contact cleaner Gazim spoke of would certainly be something worth trying though.
Stuart | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This is gonna sound bogus, but I have used it and there are hundreds of oldtime radio restorers that use it to clean noisy wirewound pots. WD-40. There really isn't much lubrication in WD-40 just spray some on a surface and look at it the next day, it will have evaporated. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used electronic contact cleaner on mine. By the way the pots in the radio use a metal wiper on carbon. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 4/0 steel wool and truckermix's idea elect. contact cleaner
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
