10 members (Opelika Tom, farmallb, Otto Skorzeny, moparguy, Oswald, Hush, RoadsScholar, Samantha, 2 invisible),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did you find/push the switch shaft retainer button?
When you push that all the way down, you should be able to pull out the knob/rod.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is that yours, DADS50?
Very nice.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks Yes, those are my chubby mitts  | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thumbs up Gus, great how-to, couldn't be any more clear. Denny G
Denny G Sandwich, IL
| | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Nice video, I appreciate the time you took to do it. It saves all of us a considerable amount of time when somebody bitchen like you does an instructional video! | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Well done on the video tip. One of those small jobs until you see it or do it that can be pretty puzzling. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | thank you for the comments. I appreciate them.
I should of added to disconnect the battery first,
but was mainly just showing the release button.
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Thank you!
By the way, your other video showing the restoration and dedication referenced in your signature, is great too! | | |
