1 members (baldeagle),
36
7
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | My fabricator is completing my cab repair and floorboard installation. I am very happy with the work performed so far. One thing he suggested was to cover the spot where the battery was originally located under the passenger side floor and relocate the battery. I was wondering if anyone had relocated their battery on 47-53 Chevy trucks and if so what locations are the best. I am ruling out under the hood and want a frame mount battery box. I am thinking behind passenger front tie or behind passenger splash apron, | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Will the new location be as easy to get to and as much out of the way as is the original location?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is an after-market battery box that drops down. It can be mounted in the original location. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | And if you get the stainless steel version it works great and lasts forever. Use a side post battery so the cables can be disconnected first and it drops out in ten seconds plus the cables don't have to be long enough to allow for the battery to lower down.
Evan
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I relocated mine under the hood in the inner fender.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | A previous owner of my '54 panel truck used what looks like the battery tray out of a '55.2-'59 and mounted it on the firewall. The original box has been cut off the frame along with the running board brackets. I may move the battery back under the floor when I get around to replacing the brackets to put the boards back on. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The neatest thing about this era is they used real estate that is unused and left dormant while the engine compartment is all full and cluttered. I am very pleased to have my dual MC and my battery under the floor. It keeps the bonnet all nice and organized!  | | |
