| | | Forums66 Topics128,113 Posts1,056,580 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | im wanting to remove my ignition tumbler from the switch housing and give it a good cleaning and oiling, how do i get it out??/ there is a small hole in it thats for something like this but how??? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | dbone:
What year? You should be able to insert the straightened end of a small paper clip into the hole and release the tumbler. That is the way to release the '64-'66 Chevy truck ignition tumbler. I hope this helps.
Tony | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | counter clockwise I believe, clockwise would leave the ignition hot
Bill | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Insert paper clip into hole on tumbler face and use the key to turn the tumbler COUNTER clockwise until it stops; then it should slide out nice an easy.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It has to be in a certain position, which is different on different switches. There's a little button with spring tension behind the hole. If you don't feel it in one position, try another.
In the case of Dbone's '51, if I remember right, it only has off and on. It has to be turned on to remove the cylinder. | | |
