6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#101043 06/05/2007 6:15 AM
Junior Member
Junior Member
1 Offline
The fuel guage on my 54 chevy pickup is not registering. It is still the original 6 volt system. How can you test whether the guage is bad or the fuel tank float is bad? I would love to solve this problem. Thanks.
#101044 06/05/2007 1:31 PM
Read some of the previous posts in this forum and you will find a good solution to your problem or use the search function. I have a 54 as well and continue to have fuel gauge problems after a complete rewire job and several gauges and sending units.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#101045 06/05/2007 2:11 PM
Papa Ed is right - there has been much posted on how to diagnose Fuel/Gas gauge problems. Before searching, however, it might be good to check the Gasoline Gauge Problems troubleshooting table in the Shop Manual (below) and also check out Randy Rundle\'s Tech Tip on Gas Gauge Problems . Randy is the moderator of this Electrical Forum.
The quickest test to see if a gauge is good is to disconnect the lead to the sender at the back of the gauge. If the gauge pegs to full (with the ignition on), you have a good gauge and your problem is elsewhere. If the gauge does not peg to full, the gauge might be bad or you might have other problems. This diagnosis is not simple. The biggest culprit is bad grounds (at the sender, and some say at the gauge).
Tim
#101046 06/06/2007 6:18 AM
Junior Member
Junior Member
1 Offline
Thanks for the advice. I will try the quick test first.
#101047 06/06/2007 10:39 PM
When you do your search...there will be tons of answers, what happened to me is I put my tank in and I krimped the sending wire,upon further investigation my sending wire was very very old and Brittle..I ran new wires,ground also. So when you have exhausted everything else like I did...it turned out to be my own fault...and pretty simple.
HURRY UP AND WAIT 55 235 3/4
