| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 7 Junior Member | | Junior Member Joined: Apr 2007 Posts: 7 | The fuel guage on my 54 chevy pickup is not registering. It is still the original 6 volt system. How can you test whether the guage is bad or the fuel tank float is bad? I would love to solve this problem. Thanks. | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | Read some of the previous posts in this forum and you will find a good solution to your problem or use the search function. I have a 54 as well and continue to have fuel gauge problems after a complete rewire job and several gauges and sending units.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Papa Ed is right - there has been much posted on how to diagnose Fuel/Gas gauge problems. Before searching, however, it might be good to check the Gasoline Gauge Problems troubleshooting table in the Shop Manual (below) and also check out Randy Rundle\'s Tech Tip on Gas Gauge Problems . Randy is the moderator of this Electrical Forum. The quickest test to see if a gauge is good is to disconnect the lead to the sender at the back of the gauge. If the gauge pegs to full (with the ignition on), you have a good gauge and your problem is elsewhere. If the gauge does not peg to full, the gauge might be bad or you might have other problems. This diagnosis is not simple. The biggest culprit is bad grounds (at the sender, and some say at the gauge). Tim | | | | | Joined: Apr 2007 Posts: 7 Junior Member | | Junior Member Joined: Apr 2007 Posts: 7 | Thanks for the advice. I will try the quick test first. | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | When you do your search...there will be tons of answers, what happened to me is I put my tank in and I krimped the sending wire,upon further investigation my sending wire was very very old and Brittle..I ran new wires,ground also. So when you have exhausted everything else like I did...it turned out to be my own fault...and pretty simple.
HURRY UP AND WAIT 55 235 3/4
